MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery
  • MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Fix Kit
  • MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Part Only
  • 360°
360
84,99 $
84,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
This Replacement Battery compatible with MacBook Unibody (Model No. A1342 Late 2009/Mid 2010) is what you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 5510 mAh—so you know you're getting the best money can buy.
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
Eigenschaften
Eigenschaften
Part #:
661-5391
Model #:
A1331
Watt Hours:
63.5 Wh
Voltage:
10.95 V
Manufacturer:
Aftermarket
Kompatibilität
MacBook Unibody A1342
2.26 GHz
2.4 GHz
Reparatur-Geschichten
Nutzeravatar
nickmalmquist's Story Photo #1376790
Mein Problem
Battery life was less and less, and OSX said to replace soon. I also wanted to replace my original hard drive with an SSD.
Meine Reparatur
The two replacements were almost seamless. The first minor problem was that I did not get the tri-lobe screwdriver to remove the battery screws. I managed to get the job done wit . . .
Nutzeravatar
mmarkovich's Story Photo #504303
Mein Problem
Battery was out completely, swapped it out with a new iFixit battery.
Meine Reparatur
Once swapped the computer did not turn on. After a day of stress, found that the problem was the small connector left of where the battery plugs in. It had come loose slightly. With tape, nudged it back in to position. This is the . . .
Nutzeravatar
Mein Problem
Dead battery
Meine Reparatur
Went fine, was easy to replace...
Mein Rat
if it needs replaced, don't hesitate, replace it
Nutzeravatar
Mein Problem
My wife's Macbook battery expanded, blowing out the trackpad and stretching the back cover. I guess it's $129 from apple to replace the battery, but we don't live near an apple store. I ordered the battery from IFIXIT and it was about $106 with tax. I searched other batteries on Amazon and other sto . . .
Nutzeravatar
Mein Problem
After upgrade to OS El Capitain, my macbook was too slow. On the same time, the battery was down for an intensive use during 6 years.
Meine Reparatur
Perfect!!! The battery was fitted and recognized by system and my macbook accept 8 gb of ram. The HD was ok and i used a software called "trim enabler" to activate T . . .
Nutzeravatar
Mein Problem
Dead battery on late 2009 Macbook (A1342).
Meine Reparatur
Replacement. Slightly more difficult than changing the batteries in your TV remote. Follow the instructions. They are very simple and to the point.
Mein Rat
Use the right tools for the job! Buy the tool kit as it has everything you will need.
Plus, once untethere . . .
Nutzeravatar
Mein Problem
My partners late 2009 Macbook started to fall apart all at once. The rubberised bottom peeled off, the batter stopped holding a charge and the fan failed.
I replaced the laptop with a new macbook and kept the old one until it failed completely which was the day after it was replaced.
A year later . . .
Nutzeravatar
Mein Problem
Battery went bad
Meine Reparatur
ordered the correct part and was fixed in a minute
Mein Rat
nope
Nutzeravatar
Mein Problem
battery was dead and magsafe board failed
Meine Reparatur
everything was great, i had 1 screw stripped from a previous repair but it wasn't too much of an issue and i broke 1 speaker connector , but that speaker was already blown and will be replaced once i can afford it.
Mein Rat
be very gentle with the speaker connectors, t . . .
Nutzeravatar
Mein Problem
After 5 years, the battery simply couldn't keep working anymore. So it was time to replace it.
Meine Reparatur
It was an easy and clear unmounting, replacement and mounting. The battery is real easy to replace, just follow the steps carefully on the tutorial.
Mein Rat
Careful on your tools! The tri-wing battery screw is reall . . .
Mehr anzeigen
