MacBook Unibody (A1342) Lower Case
  • MacBook Unibody (A1342) Lower Case
149,99 $
149,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
Jetzt kaufen
iPhone X Fix Kits
Jetzt kaufen
Artikelbeschreibung
Beschreibung
Beschreibung
Replace a dented or scratched lower case compatible with a Model A1342 MacBook Unibody laptop.
Kompatibilität
Kompatibilität
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
Eigenschaften
Eigenschaften
Part #:
922-9183, 661-5974
Model #:
A1342
Kompatibilität
MacBook Unibody A1342
2.26 GHz
2.4 GHz
Reparatur-Geschichten
Nutzeravatar
gveldman's Story Photo #462277
Mein Problem
A few weeks ago the rubber coating released it self, caused by the heat, from the lowercase of our Macbook, end 2009 version. Because the Apple replacement program was not applied on this Macbook, I decided to repair it my self. The Macbook is in perfect state, including 4GB memory and running Yosem . . .
Nutzeravatar
Mein Problem
Rubberized on original back was coming off. Rubber stretched and buckled over time
Meine Reparatur
Easy, eight screws and done. Finding the correct back from other vendors was the greatest headache
Mein Rat
call Fixit first.
Nutzeravatar
Mein Problem
My partners late 2009 Macbook started to fall apart all at once. The rubberised bottom peeled off, the batter stopped holding a charge and the fan failed.
I replaced the laptop with a new macbook and kept the old one until it failed completely which was the day after it was replaced.
A year later . . .
Nutzeravatar
Mein Problem
Bottom was missing screws, and rubber was coming off the metal. Was not affecting operation of the laptop. More cosmetic than anything.
Meine Reparatur
Got the new bottom and screws in the mail a few days after I ordered them, removed the old bottom, and installed the new bottom within minutes. Very easy to do.
Mein Rat
N . . .
Nutzeravatar
Mein Problem
Heavy-duty processing warms up the underside of my MacBook, and eventually the rubber layer on the base-plate released itself from the metal where the heat is most intense and created a large bubble. The computer couldn't sit flat on a tabletop anymore, so a replacement base-plate was required.
Meine Reparatur
The n . . .
Nutzeravatar
Mein Problem
My wife's Macbook stopped charging. After a short troubleshooting I figured out that the Magsafe connector was at fault. Also, as the laptop was mostly used on soft covered surfaces, cooling was poor, causing some overheating of the lower case, hence causing bubbling of the non slippery rubberized s . . .
Nutzeravatar
Mein Problem
Because it was broken.
Meine Reparatur
10 min. Done.
Mein Rat
It's great. Never grab your chick and through it to the bed when the laptop is sitting there. The display screen may suffer.
Nutzeravatar
Mein Problem
The old case was coming apart and needed to be replaced.
Meine Reparatur
Very easy, just remove old case and replace with the new one.
Mein Rat
Having the right screwdriver made the job easier. Would recommend that first.
Mehr anzeigen
