Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
MacBook Upper Case Cable
  • MacBook Upper Case Cable / Silver
24,99 $
24,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
Artikelbeschreibung
Beschreibung
Beschreibung
Replace a damaged upper case cable and restore function to your upper case again. This cable transmits that data from the power button, keyboard, and trackpad to your MacBook's logic board.
Kompatibilität
Kompatibilität
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
Eigenschaften
Eigenschaften
Part #:
922-7991
Kompatibilität
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
Reparatur-Geschichten
Nutzeravatar
paulxpac's Story Photo #230145
Mein Problem
My MacBook (Model 1181) is in pristine condition, so getting a new one seemed wasteful. After doing an internet search on possible causes of intermittent track pad and keyboard failure, I found it to be a consistent problem with these models. I ran thru the prescribe checks and decided to change out . . .
Nutzeravatar
lxtc's Story Photo #225913
Mein Problem
My upper case cable didn't like disassemblies much so I had to get a more cooperative one. / Excédé par des démontages intempestifs mon câble de clavier a décidé de cesser toute collaboration avec moi, d'où remplacement par un collègue au caractère plus docile.
Meine Reparatur
Thanks to the guide, all went . . .
Nutzeravatar
Mein Problem
bad, bad, bad cable
Meine Reparatur
The repair went awesome. Thanks iFixit!!!
Mein Rat
Do what iFixit says.....
Nutzeravatar
Mein Problem
Trackpad and keyboard continuously seen as being disconnected and reconnected by USB daemon. Internet was unanimous that issue was USB upper case cable.
Meine Reparatur
Replaced the part (and replaced a few stripped screws too)... but issue persists. The problem : faulty upper ase cover.
Mein Rat
When your mac starts going ha . . .
Nutzeravatar
Mein Problem
For some time I had problems with the computer recognizing my keyboard and touchpad and one day it just stopped turning on, so i opened the computer and i saw that the MacBook upper case cable was broken in one place probably because of many times of opening and closing the computer, 7 years old com . . .
Nutzeravatar
Mein Problem
Failed Logic Board. But in the process of removing the upper case to get to the logic board, the upper case cable connector fell to bits, but ifixit had one in stock.
Meine Reparatur
The repair went easy peasy with ifixit's guide, seriously. Not a screw left over.
Mein Rat
Having the right tools makes all the difference.
Nutzeravatar
Mein Problem
I had opened up my MacBook to replace my optical drive with a SATA cable so that I could connect my external SATA drive internally and get the speeds that I need. After opening the case so many times, I guess the cable just broke. This being the case, my trackpad and internal keyboard no longer func . . .
Nutzeravatar
Mein Problem
I was upgrading a computer for a kid down the street. The original plan was to upgrade his hard drive and RAM. Once we accomplished that we decided to upgrade his OS as well. That's where the "scope creep" began. His DVD player was kapoot and we couldn't get the Snow Leopard DVD out of his machi . . .
Nutzeravatar
Mein Problem
I started out having to replace the Dvd drive as it was not working. I was putting everything back when I broke the keyboard ribbon cable.
Meine Reparatur
I used the ifixit repair guides and it went smoothly. They are fantastic! My MacBook is working fine with a brand new dvd superdrive. The keyboard and the b . . .
Nutzeravatar
Mein Problem
I couldn't start the laptop, so I had to fix it.
Meine Reparatur
It went perfectly, I've received the parts in just five days, by regular mail. Considering that I live in Spain. That was very fast.
Mein Rat
Just be very careful with the Mackbook Upper case and it should go fine, and that in the other end of the cable(the on . . .
Mehr anzeigen
