Unibody 8x SATA SuperDrive (Pre-Mid 2009)
  • Unibody 8x SATA SuperDrive (Pre-Mid 2009) / Used
Zustand: Gebraucht
49,99 $
49,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Schon mal was repariert? Genial!
Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
Wir sind alle Genies
Artikelbeschreibung
Beschreibung
Beschreibung
Mankind's early attempts at spinning amounted to sending fleets of feather-coated sailboats in opposite directions off the ends of the earth, in effort to tickle the resting turtle on whose back it rested. Delegate the dizziness to your MacBook today with our Unibody 8x SATA SuperDrive (Pre-Mid 2009).
Dual-layer SATA drive. Metal mounting bracket and orange ribbon cable not included.
Note: This optical drive has a different connector than previous Apple drives.
Kompatibilität
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 17" Unibody
2.66 GHz (Early 2009)
2.8 GHz (Mid 2009)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
MacBook Unibody Model A1278
2 GHz
2.4 GHz
Reparatur-Geschichten
Nutzeravatar
Sondre Selnes's Story Photo #257497
Mein Problem
The fan on my MacBook Pro was reaching its end. It was terrible noisy ! I was in the middle of a programming project for the iPhone and making video guide for the new software, when the fan of my computer broke down. I had to stop all recording (Big Blue Yeti mic, ScreenFlow recording...).
Meine Reparatur
The vi . . .
Nutzeravatar
Mein Problem
Old drive was becoming unreliable
Meine Reparatur
Instructions were spot on.
Mein Rat
Tweezers are a must on this repair. The small screws are easy to remove but the bulk of the time is spent replacing them when you do not use tweezers. I used a plastic knife rather than a spudger. Worked just fine.
Nutzeravatar
Mein Problem
Fan bearing started getting noisy and then fan started to be slow/intermittent causing overheat shutdown of the MacBook.
Meine Reparatur
Watched your video to see what I was in for. Seemed relatively straightforward. Opened up the case and got to the fan. 2 of the 3 Philips screws came out easy. One was REALLY torqu . . .
Nutzeravatar
Mein Problem
The old fan had worn out bearings which caused lots of noise and bad performance.
Meine Reparatur
The switch went well. Took about 30 minutes because the screws were stripped. The comments were very helpful.
Mein Rat
If the screws are stripped, take a similar size flat screwdriver and put at 45 degrees into the screw so the s . . .
Nutzeravatar
Mein Problem
CPU temperatures had started to spike on my laptop (80C or higher) while doing mundane things at low percentages of CPU, and fan didn't spin up to cool the machine. Apple did diagnostics, said all was well. Temperature Gauge Pro detected a problem with fan, however, so I ordered a replacement to s . . .
Nutzeravatar
Mein Problem
Loud noises prompted me to take my Macbook Pro to the Genius Bar. They wanted to keep it for 3+ days to replace the fan, at a pretty significant cost. I happen to be blessed with a very smart teenager who cut his teeth on taking Mac's apart. Quick order on iFixit, an even faster delivery, and voi . . .
Nutzeravatar
Mein Problem
battery only lasted about an hour fully charged, and it the whole computer would rapidly overheat.
Meine Reparatur
A bit scary. The battery went in without a hitch, but when removing the old fan, the socket ripped off of the circuit board. I ended up soldering the individual wires back on. Now it works great though! . . .
Nutzeravatar
Mein Problem
The old fan had become noisy - bearings worn out probably. (After taking it out, I could see the blades spun crooked.)
Meine Reparatur
Pretty easy repair, only 3 internal screws. The connector is a little tricky since it's so small, you tend to think you're gonna break it. Go slowly around the edges and it'll com . . .
Nutzeravatar
Mein Problem
My fan was making a god awful sound whenever my macbook would start heating up. This had been happening ever since an unfortunate crepe experience where I managed to spill lemon-sugar syrup into my keyboard.
Meine Reparatur
The repair was incredibly straight forward. It was a very minimal risk procedure.
Mein Rat
Be prepared . . .
Nutzeravatar
Mein Problem
The blades on the original fan had broken and was making a lot of noise when it spun up.
Meine Reparatur
I've opened the computer many times before so the repair was a piece of cake. ~5 minutes in total.
Mein Rat
Mehr anzeigen
