Repariere deine Sachen
Recht auf Reparatur
Store
iMac Intel 27" (2012-2019) Adhesive Strips
  • iMac Intel 27" (2012-2019) Adhesive Strips / Fix Kit
  • iMac Intel 27" (2012-2019) Adhesive Strips / Part Only
19,99 $
19,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This complete set of replacement adhesive strips is specifically cut to be compatible with 27" iMacs from Late 2012 to 2019 and the iMac Pro.
  • The individual adhesive strips are labeled to indicate their correct location as shown in the replacement guides.
The unique design of the 27" iMac requires the replacement of the adhesive strips whenever the display assembly is removed. Fortunately, these adhesive strips are actually a foam tape, easily cut with an iMac Opening Wheel. Unfortunately, the display has to be removed every time anything needs to be replaced or upgraded inside the machine.
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • iMac Intel 27" A1419 Late 2012 to 2015
  • EMC 2546, 2639, 2806, 2834, 3070
  • iMac Intel 27" Retina 5K Display 2019 A2115 EMC 3194
  • iMac Pro A1862 EMC 3144
Kompatibilität
iMac Intel 27" Retina 5K Display (Mid 2017)
A1419 EMC 3070 iMac18,3 3.4 GHz
A1419 EMC 3070 iMac18,3 3.5 GHz
A1419 EMC 3070 iMac18,3 3.8 GHz
A1419 EMC 3070 iMac18,3 4.2 GHz
iMac Intel 27" EMC 2546
A1419 Late 2012 iMac13,2 2.9 GHz
A1419 Late 2012 iMac13,2 3.2 GHz
A1419 Late 2012 iMac13,2 3.4 GHz
iMac Intel 27" EMC 2639
A1419 Late 2013 iMac14,2 3.2 GHz
A1419 Late 2013 iMac14,2 3.4 GHz
A1419 Late 2013 iMac14,2 3.5 GHz
iMac Intel 27" Retina 5K Display (Late 2014 & 2015)
A1419 EMC 2806 Late 2014 iMac15,1 3.5 GHz
A1419 EMC 2806 Late 2014 iMac15,1 4.0 GHz
A1419 EMC 2806 Late 2015 iMac15,1 3.3 GHz
A1419 EMC 2834 Late 2015 iMac17,1 3.2 GHz
A1419 EMC 2834 Late 2015 iMac17,1 3.3 GHz
A1419 EMC 2834 Late 2015 iMac17,1 4.0 GHz
A2115 EMC 3194 iMac19,1 3.0 GHz
A2115 EMC 3194 iMac19,1 3.1 GHz
A2115 EMC 3194 iMac19,1 3.6 GHz
A2115 EMC 3194 iMac19,1 3.7 GHz
iMac Pro
A1862 EMC 3144 Late 2017 iMacPro1,1 2.3 GHz
A1862 EMC 3144 Late 2017 iMacPro1,1 2.5 GHz
A1862 EMC 3144 Late 2017 iMacPro1,1 3.0 GHz
A1862 EMC 3144 Late 2017 iMacPro1,1 3.2 GHz
3 weitere Geräte zeigen
Kundenbewertungen
