54 Bit Driver Kit
  • no image
54 Bit Driver Kit
Nicht zum Verkauf
Nicht zum Verkauf
Nicht zum Verkauf
Artikelbeschreibung
Beschreibung
Beschreibung
This product has been discontinued and replaced with our Mako Driver Kit - 64 Precision Bits
  • The comprehensive standard in precision screwdriver bit sets, features 54 carefully selected bits—chosen with data collected from our thousands of free repair guides.
  • This kit forms the base of our popular Classic Pro Tech Toolkit , the industry standard for computer repair technicians and businesses.
If you're looking for replacement or legacy bits, or you just want larger and even more rare bits, be sure to also take a look at iFixit's newest bit kit and 4mm Screwdriver Bits.
Kit Contents:
  • 4 mm Aluminum Driver - featuring a magnetic socket, rubber grips, and a ball-bearing swivel top
  • Flexible Shaft Extension - snake into hard to reach places
  • 60 mm Shaft Extension - doubles as a T-handle for extra torque
  • 1/4" Adapter - use this kit's 4 mm bits in standard 1/4" drivers
  • 54 bits in the following sizes:
    • Pentalobe sizes 2, 5, 6 (iPhone, MacBook Air, MacBook Pro)
    • Flathead sizes 1, 1.5, 2, 2.5, 3, 3.5, 4 mm
    • Phillips sizes #000, #00, #0, #1, #2
    • JIS sizes 000, 00, 0, 1
    • Torx sizes T3, T4, T5, T6
    • Torx Security TR7, TR8, TR9, TR10, TR15, TR20 (compatible with non-security)
    • Hex sizes 0.7, 0.9, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5, 6 mm
    • Square sizes #0, #1, #2
    • Triangle size 3 mm
    • Tri-point sizes #0, #1
    • Nut Driver sizes 2.5, 3, 3.5, 4, 5 mm
    • SIM Eject size 0.8 mm
    • Magnetic Pickup size 4 mm
Reparatur-Geschichten
luisarodriguez's Story Photo #763935
Mein Problem
Need tools that could be used to repair anything. I fix it because now a days it's possible.
Meine Reparatur
I like working on electronics, G scale model trains, or anything that breaks. Most of my repairs are tiny complicated pieces that require specialized tools. ifixit tools make the job much easier to take apar . . .
Mein Problem
After 5 years battery kept showing up as 'service battery'
Meine Reparatur
Following this guide was very straight forward and simple!
Mein Rat
Take your time. Its easy but follow the steps. Take your time picking up the screws so you dont drop them etc. great guide, thanks!
Mein Problem
I have several sets of jewelers screwdrivers and none of them could get get the job done. Yours did the trick.
Meine Reparatur
Fast and easy.
Mein Rat
Good set to have.
Mein Problem
The disc drive in both my 1st gen reverse compatible PlayStation 3 and my wii were not accepting game or movie discs. There was a rattle in the disc compartment in both. Come to find out my copious amount of children decided to stuff the systems with paper clips, safety pins and coins. Thanks to . . .
Mein Problem
Needed to replace the hard drive in an iMac 24"
Meine Reparatur
It went well. Very impressed with the written and video instructions to open the unit up and replace the hard drive.
Mein Rat
Use the videos!
Mein Problem
The trackpad was not clicking
Meine Reparatur
The repair was a complete failure. I was able to get the trackpad out without any issues. I cleaned the edges of the trackpad with a toothbrush and adjusted the screw. I replaced the trackpad, and reinserted the trackpad data cable. I then inserted the keyboard ribbon c . . .
Mein Problem
I noticed a while back that the MagSafe connector was getting really hot, hot enough that it fried the two outermost terminals in the DC-In Board's port. I could only charge it when it was off or sleeping - the MagSafe connector would overheat any time I used the computer while charging. I took it . . .
Mein Problem
Dead iMac battery! I inherited an iMac with still plenty of life in it, but a failing battery.
Meine Reparatur
Super easy! Took me 5 minutes to replace with the right tool! Thanks for the great toolkit! :)
Mein Rat
There are two different size screws on the iMac body -- it helps to keep track of which go where. I also used th . . .
Mein Problem
It was not a fix, but more a need. I recently purchance a nice spyderco ukpk knife and wanted to switch the scales on it for a custom set. So I needed a small torx bit set to desasemble it. And I was all ready eyeballing this kit for a long time. So this was the perfect time to buy this super nice . . .
Mein Problem
my mom has been wanting to upgrade her aspire 5100 memory ram cause its so freakin slow! it has only, 1gb of ram, she thought of buying a new laptop but i prefer buying a new memory ram, so i bought your tools.
Meine Reparatur
it was an easy repair job, but it took me longer to close it because it has 9 clips (idk w . . .
Mehr anzeigen
