Artikelbeschreibung
Beschreibung
Jump start your business in board level repair!
This collection of more than 50 different components is perfect for anyone learning microsoldering or scaling their board components inventory.
Practice mounting a Display Data FPC or try your hand at microsoldering a truly microscopic Backlight Filter. Once you've got your board level repair chops, use these repair components to fix many common board level challenges that come your way. Your business will earn more money—and save more devices from the landfill—than ever before.
If you’re curious and want to know more about learning to microsolder, here’s some good reading and some good watching to get you started.
Kit Inhalt
- 2 pieces iPad 2/3/4 Digitizer FPC Connector (J3010)
- 2 pieces iPad 2 LCD FPC Connector (J2201)
- 20 pieces iPad 2/3/4/Mini/Mini 2 Backlight Filter L2200
- 2 pieces iPad 3 LCD FPC Connector (J2200)
- 2 pieces iPad 3/4 Audio FPC Connector (J3700)
- 2 pieces iPad 4 Home FPC Connector (J5950)
- 10 pieces iPad Air Backlight Filter L7080, 7085
- 2 pieces iPad Air Home FPC Connector (J6300)
- 2 pieces iPad Air Lightning Connector Black
- 2 pieces iPad Air Lightning Connector White
- 2 pieces iPad 2/3/4/Mini/Mini 2 Backlight Diode
- 10 pieces iPad LCD filter L2201
- 2 pieces iPad mini 2 & mini 3 Lightning Connector Black
- 2 pieces iPad mini 2 & mini 3 Lightning Connector White
- 2 pieces iPad mini Digitizer FPC Connector J1700
- 10 pieces iPad mini FL7500
- 2 pieces iPad mini Lightning Connector Black
- 2 pieces Pad mini Lightning Connector White
- 2 pieces iPhone 5 U2 A1608A1 Tristar
- 2 pieces iPhone 5/5c/5s 343S0628 Sage Touch IC
- 10 pieces iPhone 5/5s/5c FL11 Filter
- 2 pieces iPhone 5c LCD FPC Connector (J5)
- 2 pieces iPhone 5c/5s/6/6 Plus Backlight Driver
- 2 pieces iPhone 5s Digitizer FPC Connector (J4)
- 2 pieces iPhone 5s Dock FPC Connector (J7)
- 2 pieces iPhone 5s LCD FPC Connector (J5)
- 2 pieces iPhone 5s Power and Volume FPC Connector (J2)
- 2 pieces iPhone 5s U2 A1610A3 Tristar
- 10 pieces iPhone 5s/5c C275 Capacitor
- 10 pieces iPhone 5s/5c C9 Capacitor
- 2 pieces iPhone 5c/5s/6 Plus Backlight Diode
- 10 pieces iPhone 5s/6/6 Plus Backlight Filter FL24, 25, 26, 2024, 2025, 2026
- 10 pieces iPhone 5c/5s/6/6 Plus LCD Filter
- 2 pieces iPhone 6 Home FPC Connector (J2118)
- 10 pieces iPhone 6 C1530 BL Cap
- 10 pieces iPhone 6 C5202_RF
- 2 pieces iPhone 6 Digitizer FPC Connector (J2401)
- 2 pieces iPhone 6 LCD FPC Connector (J2019)
- 2 pieces iPhone 6 Plus Digitizer FPC Connector (J2401)
- 2 pieces iPhone 6 Plus Home FPC Connector (J2118)
- 2 pieces iPhone 6 Plus LCD FPC Connector (J2019)
- 2 pieces iPhone 6/6 Plus 343S0694 Touch IC
- 2 pieces iPhone 6/6s/7 Backlight Diode
- 2 pieces iPhone 6s LCD/Digitizer FPC Connector (J4200)
- 2 pieces iPhone 6s Plus LCD/Digitizer FPC Connector (J4200)
- 10 pieces iPhone 6s/6s Plus/7/7 Plus Backlight Filter
- 2 pieces iPhone 6s/6s+/7 Backlight Driver LM3539
- 2 pieces iPhone and iPad Tristar A1610A3
- 2 pieces iPhone Cumulus BCM5976C1KUB6G Touch IC
- 2 pieces iPhone Display PMU 65730A0P
- 2 pieces iPhone Tigris SN2400B0 Charging IC
- 2 pieces iPhone and iPad LCD Data Choke
Kompatibilität
- iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, and 7 Plus
- iPad 2, 3, and 4
- iPad Air
- iPad mini, mini 2, and mini 3
Kompatibilität
24 weitere Geräte zeigen
