Repariere deine Sachen
Recht auf Reparatur
Store
Gamebit 4.5mm
  • Gamebit 4.5mm
  • Gamebit 4.5mm / Japan / Fixed Blade
Gamebit 4.5mm
24,99 $
24,99 $
SPAR DIR DAS UPGRADE
Mach dein iPhone so gut wie neu mit unseren Fix Kits.
Jetzt entdecken
Jetzt entdecken
Artikelbeschreibung
Beschreibung
Beschreibung
Used in many video game consoles and other devices, this type of fastener is most commonly called by it's incorrect nickname of 4.5mm Gamebit. The correct fastener type and size is 4.6mm Line Head Screw.
Until now, only poor quality 1/4" drive "Gamebits" have been available in the USA, that are unable to reach the recessed screws found on some consoles.
Reparatur-Geschichten
Nutzeravatar
Mein Problem
Front glass was shattered after a drop. Touch still worked but was annoying.
Meine Reparatur
Followed the guide and repair was easy. Some screws inside were missing from a bad repair job before so it took a little longer than expected but everything went smoothly.
Mein Rat
Be sure to watch out for the digitizer cable getting . . .
Nutzeravatar
Mein Problem
A friend asked me to make an upgrade to his Nintendo GameCube. He asked for an addition of a "Xeno-GC" driver chip.
Meine Reparatur
The GameCube case needs to be opened with a proprietary "GameBit" driver. Aside from that tool, I only needed to use two smaller Phillips drivers to disassemble every major assembly wit . . .
Nutzeravatar
Mein Problem
i had to open a gamecube that had a fan problem. FIXED!
Meine Reparatur
Smoothly, no problem with those superb gamebits
Mein Rat
Get your stuff on IFIXIT because people who got equiped with IFIXIT fix like PRO!
Nutzeravatar
Mein Problem
MY SON WANTED TO PLAY IT AGAIN AS HE FOUND MY BOX WITH SEGA GAME GEAR, ATARI LYNX AND THE VIRTUAL BOY IN IT. DON'T LEAVE BATTERIES IN YOUR ELECTRONICS AND PUT THEM INTO STORAGE! YOU'LL LEARN HOW TO CLEAN LEAKY BATTERY SPLOOGE REALLY GOOD.
Meine Reparatur
FINE, EXTREMELY SIMPLE REPAIR. REMOVE 2 FLEXIBLE RIBBONS AND . . .
Nutzeravatar
Mein Problem
I got this for my gamecube just so i could swap the casing. I have the old gamecube with the digital av out but the console itself looked bad and had scratches. I had another one so i swapped the insides and now my gamecube looks amazing.
Meine Reparatur
The gamebit worked flawlessly and with ease. The quality feel . . .
Nutzeravatar
Mein Problem
hey guys you've been great to deal with,no big repair going on just yet trying to teach myself as much as i can first and this site is very helpful,I am now and always will be a loyal customer
Meine Reparatur
no repair just using this site and it friends to learn and try to apply to things in the future,this is an e . . .
Mehr anzeigen
