Repariere deine Sachen
Recht auf Reparatur
Store
Mahi Driver Kit - 48 Bit Driver Kit
  • Mahi Driver Kit - 48 Bit Driver Kit
34,99 $
34,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
The Mahi Driver Kit includes iFixit’s 1/4" aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top—plus 48 driver bits.
Spanners, Squares, and Splines—oh my! In addition to standard Phillips and Flathead, this bit kit includes all the 1/4" form factor bits you’ll need to handle the toughest and torque-iest fasteners in any home or shop project.
All our next-gen bit kits have been re-engineered for maximum utility. The bit kit lid is held in place with magnets to increase product lifespan (no more broken hinges or clasps) and also mounts to the back of the bit kit case to keep it out of the way while you do your work. Or, if you need help keeping your screws and parts organized, use the lid’s integrated sorting tray.
Kit Inhalt
Kit Inhalt
  • Easy-to-Open Magnetized Case
  • Lid with Built-in Sorting Tray
  • 1/4" Aluminum Bit Driver
  • 48 Screwdriver Bits
    • Phillips - 0, 1, 2, 3
    • Flathead - 4, 6, 8 mm
    • Hex Security - 4, 5, 6, 7, 8 mm
    • Hex Security SAE - 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
    • Pozidriv - PZ1, PZ2, PZ3
    • Spanner - 4, 6, 8, 10, 12
    • Square - 2, 3
    • Spline - M5, M6, M8
    • Torx Security - TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
    • Tri-wing 1, 2, 3, 4
    • Clutch 1, 2, 3
    • Schrader Valve
    • 1/4" Driver to 1/4" Socket
Eigenschaften
Eigenschaften
Driver Material:
Anodized Aluminum
Foam:
EVA
Bit Metal:
6150 Steel
Case Material:
ABS
Kundenbewertungen
