Repariere deine Sachen
Recht auf Reparatur
Store
Minnow Driver Kit
  • Minnow Driver Kit
  • Minnow Driver Kit
  • Minnow Driver Kit
  • Minnow Driver Kit
Minnow Driver Kit
14,99 $
14,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
If you find yourself out and about and in need of a fix, this kit will have you covered. Measuring a portable .9" x 1.8" x 4.9", repair a lot with a little pocket-sized Minnow Driver Kit.
We built the Minnow using data from thousands of repair manuals and teardowns, ensuring you have the most compact assortment of bits for electronics repair. Our 4 mm precision bit driver handle has an integrated SIM Eject pin, magnetic bit socket, knurled grip, and swivel top—and each of the 16 precision bits has a 4 mm hex shank and extended-reach long neck.
Standard bits like Phillips and Flatheads will get you into most small household appliances and electronic devices, while security and exotic bits like Pentalobes will gain you access into Apple devices like iPhones and MacBooks. Whether you're a professional fixer or a weekend warrior, accidents happen everywhere. The Minnow has what you need to disassemble and repair smartphones, laptops, wearables, drones, pocket knives, and more—on the go or at home.
Kit Inhalt
Kit Inhalt
  • Easy-to-Open Magnetized Case
  • Lid with Built-in Sorting Tray
  • 4 mm Precision Bit Driver with Integrated SIM Eject Tool
  • 16 Screwdriver Bits
    • Phillips - 000, 0, 1
    • Flathead - 1, 2.5 mm
    • Torx - T3, T4, T5
    • Torx Security - TR6, TR8, TR10
    • Pentalobe - P2, P5
    • Tri-point - Y000, Y0
    • iPhone Standoff Bit
Eigenschaften
Eigenschaften
Driver Material:
Polymer
Foam:
EVA
Bit Metal:
S2 Steel
Case Material:
ABS
Dimensions:
.9" x 1.8" x 4.9" / 2.2 x 4.5 x 12.4cm
Kundenbewertungen
