Phillips #2 Screwdriver
  • Phillips #2 Screwdriver
2,99 $
2,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
iPhone Akku Fix Kits
Nur $29.99
Buy Now
Nur $29.99
Buy Now
Artikelbeschreibung
Beschreibung
Beschreibung
Unless you require a #2 Phillips driver for a deeply recessed screw, we recommend purchasing our 6-in-1-Screwdriver, which includes a Phillips #2 driver.
Eigenschaften
Eigenschaften
Shaft Diameter:
1/4" / 6mm
Shaft Length:
4" / 100mm
Reparatur-Geschichten
Nutzeravatar
Mein Problem
Computer was constantly running fans with little to no actual load. Upon closer investigation the computer was getting as high as 90 degrees Celsius when doing moderately demanding tasks.
Meine Reparatur
Opened the case and saw a bunch of dust everywhere. After the dust was removed the real problem revealed itself. . . .
Nutzeravatar
Mein Problem
Replaced built in optical drive with 250GB SSD drive. System was running really slow.
Meine Reparatur
It went well. Followed instructions and was pretty straight forward. Ran into a few hurdles....The screws can easily fall down into the case, which was very annoying. There is also a cable that has a very sensitive . . .
Nutzeravatar
Mein Problem
No facilities available in Australia, apparently.
Meine Reparatur
Quite ok. Thanx for online instructions.
Mein Rat
Spludger
invaluable.l
Nutzeravatar
Mein Problem
My iMac 27 Inch i5 always frozen...
Meine Reparatur
Very well, I managed to happily. It 'just install "Fan control" fan set at maximum speed and the problem is solved!. For an excess of zeal, oh then apart my iMac 27 to carry out additional cleaning.
Mein Rat
No, nothing special
Nutzeravatar
Mein Problem
The power supply of my Imac was broken
Meine Reparatur
My iMac is a 24" aluminum one, unfortunately there was no official guide on the website. However, there was a guide for changing the power supply in a 20" iMac, so I used that. There was also a video of the friendly lady, who made the repair look very easy. I al . . .
Mehr anzeigen
