Artikelbeschreibung
Beschreibung
The perfect tool for cutting, stripping, and crimping.
- 10-22 Gauge Wire Stripper
- Screw Cutter
- Wire Cutter
When it comes to wire working, no tool is more handy than a wire stripper. These pliers feature special grooves specially designed to cut only the casing on the wire and not the metal underneath. These are absolutely a must-have for both the professional electrician and the hobbyist tinkerer.
If you're serious about wire stripping, be sure to check out our Lightweight Wire Strippers for another awesome pair of wire strippers. If you're looking to outfit yourself with a great soldering setup, check out our Soldering Workstation.
Kundenbewertungen
