iSesamo Opening Tool
  • iSesamo Opening Tool
  • 360°
360
9,99 $
9,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Crafted for one purpose
A thin sheet of springy steel, designed to slide easily between panels and into microscopic cracks. An expertly curved tip, perfected to get the right angle on electronic casing clips. And with a no-slip grip, this tool is much more effective and reliable than other case opening methods.
  • This tough tool nimbly pops open modern small electronics casings.
  • Springy steel blade features a smart tip design and a handle with a great no-slip grip.
Be sure to exercise caution when using this tool. With its great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
Produkt-Video
Reparatur-Geschichten
tomm's Story Photo #1334078
Mein Problem
iPod Photo purchased when first released. Replaced battery using iFixit parts, tools, and guide six or seven years ago. That battery started quitting when indicating about 1/2 charged. Decided time to fix it again.
Meine Reparatur
I couldn't get the case open. Trying from the right side as indicated in the guide . . .
Mein Problem
Yes I’m learning how to repair iPhones with these tools. Thank you!
Meine Reparatur
It went good
Mein Rat
I fixed an iPhone 5s
Mein Problem
My phone got dropped at the airport and cracked the upper left corner of just the glass, still worked fine, but I researched changing the glass only and most of the feedback indicated that you'd damage the digitizer in the process so I opted to order the screen and digitizer assembly. My wife had d . . .
Mein Problem
Reemplace el conector de carga, la guía me sirvió mucho :)
Meine Reparatur
Fue un poco complicada pero al fin y al cabo logré la reparación
Mein Rat
Usen una luz blanca para prestar atención al lcd, este se podría quemar por el calor
Mein Problem
An older iPhone 4 with a cracked screen was going to waist in my dresser. I found myself reading for it when my new fone was on the charger but e screen was a mess.
Meine Reparatur
The repair wint great. No issues not if is a pleasure to use for late nite browsing and email. I forgot hi good the smal screen actu . . .
Mein Problem
My iphone 6 screen was broken and i bought from another seller and it appeared to be of poor quality so i decided to buy from ifixit and it went all well
Meine Reparatur
Smooth. I had the islack which works like a charm. Easy to open the iphone
Mein Rat
Buy from reliable sources like ifixit
Mein Problem
My daughter cracked her iPhone 5S screen while at college after only having the phone for about 5 months. I decided I would fix it myself while she was home for Christmas break. I also decided that while I was at it, I would fix her older iPhone 4S cracked screen and sell that phone to help pay fo . . .
Mein Problem
I was tasked with replacing the battery in 14 Ipad Gen 1's - That seemed easy enough, since I'd been repairing PC for Years.
Meine Reparatur
The Repair started out ok I received my tools, and went right to work, using the iSesamo Tool I opened the first ipad pretty easy, The only issue I have with the iSesamo Tool i . . .
Mein Problem
The charging port on my iPhone 5 was shorted.
Meine Reparatur
After looking at the repair guide for a while, I managed to open and fix the iPone for the first time in about an hour.
Mein Rat
Pay attention to how you remove the loudspeaker. That almost tripped me up while reinstalling.
Mein Problem
Wacko iPad decided to fly out of my hand. All went well for about 2 seconds, then it fell down a flight of concrete and steel stairs.
Meine Reparatur
All went as described. My only problem was the chassis was somewhat deformed at the corners, causing some difficulty fitting the bezel. Turned out okay though.
Mein Rat
Dry fit . . .
Mehr anzeigen
