Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
« Zurück zu allen Geschichten
Battery worked fine. Phone, not so much.
manterdg -
iPhone 5s
How to replace the battery in your iPhone 5s
30 Minuten - 1 Stunde
Moderate
Mein Problem
Water damaged phone. And, I damaged the battery while removing it.
Meine Reparatur
The owner left it assembled with the battery connected too long. It worked when I was done, but died by the time the owner got home. I pulled the mother board, and had the owner put all of the parts in rice over the weekend. But, it was too late. Also, I damaged the battery when I removed it. Note to iPhone 5s repairers. there is a command strip type pull tab to remove the battery. Don't bother prying it up.
Mein Rat
Note to iPhone 5s repairers. there is a command strip type pull tab to remove the battery. Don't bother prying it up. That little black "flap" at the bottom of the battery is a pull tab. Buy a replacement when you order the battery.
iPhone 5s Battery Bild
iPhone 5s Battery
$29.99
Kommentar hinzufügen
