Step 7, hex 1.5 - T6 Torx vs the 1.5mm Allen Wrench
cineset -
Mein Problem
Replacing Logic Board in PowerBook G4 15" 1.25ghz
Meine Reparatur
The repair went great - thanks.
Mein Rat
In step 7 the instructions state, "Remove the 4.2 mm 1/16" H 1.5 hex screws in either corner, next to the display (a T6 Torx driver will also do the job nicely).
I completely forgot the obvious & used the T6 ? no (didn't fit), the T7 shaved down a bit when I should have just used a 1.5mm allen wrench or hex key.
I realized this after the repair & used my allen wrench to optimize the torque.
The required tools mention the T6 & this was the only place to use it throughout the repair when actually the 1.5mm allen wrench is a much better fit but isn't mentioned in the required tools.
0 Kommentare
