Easy foot pad replacement without adhesives.
Mein Problem
Broken and dislodged foot pad is easier and cheaper to repair yourself.
Meine Reparatur
Simply repair. Took only about 5 minutes to clean the area and press the foot pad into place.
Mein Rat
Not necessary to remove the bottom of the computer case, but be certain the area is clean where the foot pad is inserted and that you line the small nub on the underside of the pad up with the hole. I used pointed tweezers and gripped the pad at the point where the nub was to help line it up. Simply press into place and it's done.
0 Kommentare
