Mein Problem
My battery was draining very fast when it got to 30% and the lighting connector was failing
Meine Reparatur
The repair took about 3 hours in two sessions. The last step of the lighting connector assembly replacement guide was missing the step at the end to separate the microphone cable from the plastic microphone insert. Everything else was clear and worked per the instructions.
Mein Rat
Add one step at the end to the lighting connector assembly install guide to separate the microphone plastic insert from the cable. When I finished with step 37 the lighting connector assembly had the plastic microphone portion connected to it. I finally figured out that they were connected with an adhesive.
0 Kommentare
