Zum Hauptinhalt wechseln
« Zurück zu allen Geschichten
Fan Replacement
ctjewett -
MacBook Air 11" Mid 2011
Bild zur Geschichte
MacBook Air 11" Mid 2011 Fan Replacement
15 Minuten
Moderate
Mein Problem
Old fan was making all sorts of noise. I didn't even realize my Mac had a fan for years until this fan started to go, and then it was obvious as a blue sky.
Meine Reparatur
Overall, it was a pretty easy repair, but a tad trickier than a standard PC laptop due to the tight tolerances and incredibly small parts. If you can put the Mac in a shallow box so no screws get lost in the process, it'll probably help considerably.
Mein Rat
The only super tricky part was sliding the new fan's ribbon cable into the slot. I used the spudger and pushed on the only small crease I could find to slide it into the slot. I suggest powering it on while still apart to verify functionality, then power it off and finish stitching everything back together.
MacBook Air 11" (Mid 2011-Early 2015) Fan Bild
$19.99
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 127
