Easy but beware of battery pull-tab adhesive
Mein Problem
My battery was not working well and phone was slow.
Meine Reparatur
I could probably do it in under a half hour and rate it easy if it weren’t for the pull-tabs. The first one worked, and the second broke halfway through. That took an extra 15 minutes to push the adhesive into a place I could grab it to complete the repair. The replacement battery is perfect and SOOOO much better than the 3-year-old one; the phone works like new! Time will tell for how long it lasts but so far so good.
Mein Rat
Be care with the pull tabs.
Ein Kommentar
If you pry up the battery a bit you can pull out the adhesive strips from the edge of the battery, between the frame and the battery. I tip is to heat the back side on the phone with a heat gun, soft strips do not snaps off that easy.
peter - Antwort
