« Zurück zu allen Geschichten
Broken Headphone Jack
Daniel -
MacBook Air 11" Early 2015
Bild zur Geschichte
MacBook Air 11" Early 2015 I/O Board Replacement
45 Minuten
Easy
Mein Problem
Part of a headphone jack was stuck inside the headphone port.
Meine Reparatur
I ordered a replacement I/O board. Removal and installation was simple.
Mein Rat
There's a hole on the backside of the headphone port. If there's no physical damage, simply removing the I/O Board and using a small pin allows for removal of any stuck pieces. (Unless you try a super glue trick you read online and end up sealing off the port.)
MacBook Air 11" (Mid 2013-Early 2015) I/O Board Bild
$99.99
The GripStick extraction tool is great for removing broken off headphone plugs that are stuck in the jack. They are available in the Parts & Tool store here on iFixit.
Alec - Antwort
I have a MacBook Air 2015 witha bad I/O board. Problem is that ordering the iFixit Pro Toolkit did me no good. One needs a Pentalobe 5 driver head to open the MacBook Air, but the “Pro” toolkit contained no such driver bit. With a magnifying glass and flashlight I studied each bit’s label. There is no Pentalobe bit. And don’t try calling iFixit for customer service; they simply ignored all my calls. I am an extremely disapointed customer.
Anthony V Toscano - Antwort
