Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein A-Solar Power Bank AL-200 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. A-Solar PowerBank AL-200 Teardown, A-Solar PowerBank AL-200 Teardown: Schritt 1, Bild 1 von 2 A-Solar PowerBank AL-200 Teardown, A-Solar PowerBank AL-200 Teardown: Schritt 1, Bild 2 von 2
    • There are three blue LEDs to show you the power in the battery.
    • There is also a handy LED to see what you are doing in the dark.
  2. A-Solar PowerBank AL-200 Teardown: Schritt 2, Bild 1 von 3 A-Solar PowerBank AL-200 Teardown: Schritt 2, Bild 2 von 3 A-Solar PowerBank AL-200 Teardown: Schritt 2, Bild 3 von 3
    • The bottom of the device.
    • It's time for some prying. Take out the rubber plugs at the bottom of the device.
    • Remove the screws which are underneath the plugs.
  3. A-Solar PowerBank AL-200 Teardown: Schritt 3, Bild 1 von 2 A-Solar PowerBank AL-200 Teardown: Schritt 3, Bild 2 von 2
    • use a flathead screwdriver or a spudger to pry open the device.
    • Don't pry at the front of the device - there are a few hooks and you do not want to break them.
  4. A-Solar PowerBank AL-200 Teardown: Schritt 4, Bild 1 von 1
    • A first glance at the inside: a big battery and the logic board.
    • There is a 1800 mAh battery in it.
    • There are two screws in the logic board, the battery is glued to the casing.
  5. A-Solar PowerBank AL-200 Teardown: Schritt 5, Bild 1 von 2 A-Solar PowerBank AL-200 Teardown: Schritt 5, Bild 2 von 2
    • The other side of the electronics.
    • And the logic board.
  6. A-Solar PowerBank AL-200 Teardown: Schritt 6, Bild 1 von 1
    • And there it is: the A-Solar PowerBank AL-200 torn down.
    • It was easy to do.
storm
552 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 5,205
