Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein A.C.Ryan PlayOn!HD zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. A.C.Ryan PlayOn!HD Teardown, A.C.Ryan PlayOn!HD Teardown: Schritt 1, Bild 1 von 2 A.C.Ryan PlayOn!HD Teardown, A.C.Ryan PlayOn!HD Teardown: Schritt 1, Bild 2 von 2
    • The ACRyan PlayOn HD with remote control.
  2. A.C.Ryan PlayOn!HD Teardown: Schritt 2, Bild 1 von 2 A.C.Ryan PlayOn!HD Teardown: Schritt 2, Bild 2 von 2
    • The rear panel with the necessary connectors.
  3. A.C.Ryan PlayOn!HD Teardown: Schritt 3, Bild 1 von 2 A.C.Ryan PlayOn!HD Teardown: Schritt 3, Bild 2 von 2
    • The location of the 2.5 HD is at the bottom of the case.
  4. A.C.Ryan PlayOn!HD Teardown: Schritt 4, Bild 1 von 3 A.C.Ryan PlayOn!HD Teardown: Schritt 4, Bild 2 von 3 A.C.Ryan PlayOn!HD Teardown: Schritt 4, Bild 3 von 3
    • The small motherboard with the USB and IR receiver PCB.
Vincent Tay
101 Reputation
1 Anleitung geschrieben
4 Kommentare
Hi,
I have a somewhat different problem my remote broke and before I buy a new one I want to try fixing mine there are two components missing which I could easily replace but I don't know the ratings or model numbers of the components. So if anyone could send me pictures of the components that would be awesome.
mpinnie - Antwort
Have you fix it? Or you had threw it away?
Bee B - Antwort
Hi
the ac Ryan is not being recognised by my laptop through USB Connection.
Is there any remedy?
Cyril Kevin - Antwort
Hi! Where can I buy the remote control of AC Ryan
Roberto Albino - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 3,393
