Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein ACEPC AK2 (AK1V 6.0) zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. ACEPC AK2 (AK1 V6.0) Teardown, Open the Top - SATA Connector - Drive - SSD - HDD: Schritt 1, Bild 1 von 1
    • You only need the screwdriver if there is a screw in the red circle. I used the screwdriver to show you how the lid is fit.
    • Remove the power adapter
    • Slide the release button to the right.
    • Now you can lift the top and put it to the side.
    Frag FixBot
    Kommentar hinzufügen
  2. ACEPC AK2 (AK1 V6.0) Teardown, How to release the silver frame.: Schritt 2, Bild 1 von 3 ACEPC AK2 (AK1 V6.0) Teardown, How to release the silver frame.: Schritt 2, Bild 2 von 3 ACEPC AK2 (AK1 V6.0) Teardown, How to release the silver frame.: Schritt 2, Bild 3 von 3
    • Release the screws of the frame.
    • You can release the screws of the drive frame ...
    • ... or leave the screws in place and pull off the black tape.
    • You need the longer screwdriver for some screws
    Frag FixBot
  3. ACEPC AK2 (AK1 V6.0) Teardown, Motherboard - Mainboard: Schritt 3, Bild 1 von 1
    • Now release the screws in the orange sircles.
    • Better release the screws on the LED board.
    • slide the board a little bit away from the outer connectors and pull it up.
    • Please dont break the walls.
    • The battery gives the board a little bit electric power. Please dont get a electric shock.
    • The antenna (in blue) is very sensitive and can easily tear off. You can carefully peel the foils with the antenna & stick them onto the black cover of the board.
    Frag FixBot
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 67
Insgesamt: 2,485
