Einleitung
PDF manual here: AGPTEK A02 Manual
Was du brauchst
Remove the microSD card, if present. You can use a flat side of a spudger
With a Pick, insert the tool and split the two parts that make the shell of the mp3 player
Use Jimmy, if the pick is too flexible for you
That's all. The screen is welded and coated with glue.
command bottons
usb port
the switch
SD card holder
