Was du brauchst
Use a spudger to lift the corners of the silicone membrane under the device.
Unscrew the Phillips head screws using a PH000 screw bit.
Insert a plastic spudger into the highlighted notch in the motherboard.
Pull the motherboard up using the spudger.
Remove the motherboard, holding the corners.
Here's a list of chips present on the motherboard:
ITE IT6613 HDMI transmitter
ITE IT6604 single-link HDMI 1.4 receiver
Nanya NT6DM16M32BC-T1 mobile 512mb DDR RAM chip clocked at 200MHz
Sigma Designs PL330B-CPE3 H.264 Encoder
Texas Instruments LVC244A octal buffer/ driver
Nuvoton NUC100RD2BN RISC ARM microcontroller clocked at 50MHz
