Was du brauchst
Use metal spudger to lift sticker
Applying some force lift the mouse top up and backward at the same time to disconnect it
Once inside pull on the scroll wheel to remove it from the board
Pull on the cable and the board should come out
Then pull out the plastic at the bottom
2 Kommentare
Scroll not working
