Zum Hauptinhalt wechseln
Einleitung
This teardown is a working Actiontec Q1000 Modem, sold by Qwest as a Qwest Q1000.
Dieser Teardown ist keine Reparaturanleitung. Um dein Actiontec Q1000 DSL Modem zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. The Qwest Q1000 modem, made by Actiontec. Port side with antennas detached. DSL and Phone in ports
    • The Qwest Q1000 modem, made by Actiontec.
    • Port side with antennas detached.
    • DSL and Phone in ports
    • 4 Ethernet ports
    • USB port, reset button, and power jack
    • Not a screw in sight.
  2. As usual, the rubber feet are hiding screws! As usual, the rubber feet are hiding screws! As usual, the rubber feet are hiding screws!
    • As usual, the rubber feet are hiding screws!
  3. Nothing really to see here... Remove the 2 antenna wires from the wifi card. One is also taped to the back of the board. The circuit board is finally free!
    • Nothing really to see here...
    • Remove the 2 antenna wires from the wifi card. One is also taped to the back of the board.
    • The circuit board is finally free!
  4. Looks like someone was generous with the thermal paste. Underneath the cover:
    • Looks like someone was generous with the thermal paste.
    • Underneath the cover:
    • Broadcom BCM6366
    • Broadcom BCM53115
  5. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  6. The Wi-Fi card lets down its shield... The chip is a BCM4322.
    • The Wi-Fi card lets down its shield...
    • The chip is a BCM4322.
  7. The inside of the top case. The antenna connectors are screwed onto the case.
    • The inside of the top case.
    • The antenna connectors are screwed onto the case.
  8. The antenna connectors have gold-plated coax connectors and standard Wi-Fi antenna connectors. What's underneath the heat-shrink? A ferrite bead to minimize interference.
    • The antenna connectors have gold-plated coax connectors and standard Wi-Fi antenna connectors.
    • What's underneath the heat-shrink? A ferrite bead to minimize interference.
  9. Testing out the light pipe with an LED throwie... The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel. Here are all the LEDS:
    • Testing out the light pipe with an LED throwie...
    • The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel.
    • Here are all the LEDS:
    • 8 of the LEDS that work with the light pipe
    • One more surface mount LED
    • A white LED for illuminating the Qwest logo
    • A dual-color (red/green) LED for the WPS status indicator.
  10. The empty shell that once held a DSL modem. The 2 detachable Wi-Fi antennas. Nothing to tear down here! The 2 detachable Wi-Fi antennas. Nothing to tear down here!
    • The empty shell that once held a DSL modem.
    • The 2 detachable Wi-Fi antennas. Nothing to tear down here!
  11. Repairability score: 8/10
    • Repairability score: 8/10
    • The entire device is held together with only 4 screws.
    • The Wi-Fi antenna connectors are screwed in and the cables are not soldered to the board.
    • The antennas are replaceable as well.
    • The heat sink is soldered in place, making removal difficult.
    • The Wi-Fi card is soldered in and held in place with silicon adhesive, making it impossible to remove without damaging the card or the device.
Angehängte Dateien
jrw01
1.125 Reputation
23 Anleitungen geschrieben
Awesome teardown! These things have gotten so simple. Those antennas would be pretty easy to repurpose for something else.
Kyle Wiens - Antwort
What are the part number, volts, and amps of the power supply?
PDXTek - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 5,683
