Zum Hauptinhalt wechseln
Dieser Teardown ist keine Reparaturanleitung. Um dein Airvape Legacy Pro zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Airvape Legacy Pro Teardown, Airvape Legacy Pro Teardown: Schritt 1, Bild 1 von 1
    • Remove the top cloth material with heat
    • The tape that holds the fabric is no longer sticky after removal. But I found that heating it up again and reapplying the fabric works!
    • Remove four Phillips head screws
    • Use a spudger to lift off the plastic panel
  2. Airvape Legacy Pro Teardown, Angled look at PCB: Schritt 2, Bild 1 von 1
    • Just another photo
  3. Airvape Legacy Pro Teardown, Under wireless charger: Schritt 3, Bild 1 von 1
    • The wireless charging coil sits on a sticky pad, can be easily lifted with tweasers
ShellingRook27
1.820 Reputation
7 Anleitungen geschrieben
Repair For You Mitglied von Repair For You
Business
1 Mitglied
11 Anleitungen geschrieben
4 Kommentare
Looking forward to seeing this continue!
andypapster - Antwort
nothing more with the teardown?
seedy53 - Antwort
I think on FC he mentioned this was still his primary device and until he replaces it, he won’t do a further tear down.
andypapster -
Yeah, that is all for now. Like Andy said I'm still using this device and will do a full destructive teardown when I replace it. I'll update the introduction with that information.
ShellingRook27 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 38
Letzte 30 Tage: 175
Insgesamt: 376
