Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Alcatel One Touch Fierce zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Alcatel One Touch Fierce Teardown, Alcatel One Touch Fierce Teardown: Schritt 1, Bild 1 von 3 Alcatel One Touch Fierce Teardown, Alcatel One Touch Fierce Teardown: Schritt 1, Bild 2 von 3 Alcatel One Touch Fierce Teardown, Alcatel One Touch Fierce Teardown: Schritt 1, Bild 3 von 3
    • Phillips #000 is highly recommended. As you can see i'm too broke for the iFixIt equivalent.
    • The iSesamo is also always handy.
    hi jon. i have a 4 day old Alcatel one touch fierce that will not power up. Can you help?
    Theo Salas - Antwort
  2. Alcatel One Touch Fierce Teardown: Schritt 2, Bild 1 von 2 Alcatel One Touch Fierce Teardown: Schritt 2, Bild 2 von 2
    • This is the Metro PCS variant of the phone in a nice metallic silver color.
    • The front of this particular device is water damaged and finger print damaged.
    I have the back off! Where ithe speaker located
    Linda Muladore - Antwort
    I have no sound! Sometimes it crackles or I'll hear part of a ringtone but that's it!!
  3. Alcatel One Touch Fierce Teardown: Schritt 3, Bild 1 von 2 Alcatel One Touch Fierce Teardown: Schritt 3, Bild 2 von 2
    • With the back plastic removed.
    • "DO NOT REMOVE"
    • Challenge accepted
    I'm finding the 2nd cover difficult to remove. It seems secured somewhere top center. Perhaps around the camera lens. I'm nervous to continue in fear I may break something. Any additional info for this step would be useful
    Julie Copeland - Antwort
    I feel the same way
    sanchezkk - Antwort
    under the void sticker there is an additional SCREW!
    capricciacolella - Antwort
  4. Alcatel One Touch Fierce Teardown: Schritt 4, Bild 1 von 1
    • The second cover is removed. We now have a better look at the components.
    Where is the wifi antenna on this phone
    Giovani Aguilar - Antwort
  5. Alcatel One Touch Fierce Teardown: Schritt 5, Bild 1 von 1
    • The battery. Doesn't last very long.
  6. Alcatel One Touch Fierce Teardown: Schritt 6, Bild 1 von 2 Alcatel One Touch Fierce Teardown: Schritt 6, Bild 2 von 2
    • The 5MP camera located on the back of the phone.
  7. Alcatel One Touch Fierce Teardown: Schritt 7, Bild 1 von 2 Alcatel One Touch Fierce Teardown: Schritt 7, Bild 2 von 2
    • The daughter board contains the Micro USB port
    Were do get?
    Lembit - Antwort
  8. Alcatel One Touch Fierce Teardown: Schritt 8, Bild 1 von 2 Alcatel One Touch Fierce Teardown: Schritt 8, Bild 2 von 2
    • The main PCB
  9. Alcatel One Touch Fierce Teardown: Schritt 9, Bild 1 von 3 Alcatel One Touch Fierce Teardown: Schritt 9, Bild 2 von 3 Alcatel One Touch Fierce Teardown: Schritt 9, Bild 3 von 3
    • The VGA camera located on the front of the phone.
  10. Alcatel One Touch Fierce Teardown: Schritt 10, Bild 1 von 2 Alcatel One Touch Fierce Teardown: Schritt 10, Bild 2 von 2
    • The remains of the front panel
  11. Alcatel One Touch Fierce Teardown: Schritt 11, Bild 1 von 2 Alcatel One Touch Fierce Teardown: Schritt 11, Bild 2 von 2
    • Trying to remove the front panel assembly.
    • It seemed to have quite a bit of adhesive.
    • Luckily i have a good amount of picks available.
    • Oh no, i think i hear cracking...
  12. Alcatel One Touch Fierce Teardown, Shoot..: Schritt 12, Bild 1 von 2 Alcatel One Touch Fierce Teardown, Shoot..: Schritt 12, Bild 2 von 2
    • Crap! i totally saw this coming.
    • To avoid this use a heat gun to loosen the glue...not too much heat though.
  13. Alcatel One Touch Fierce Teardown: Schritt 13, Bild 1 von 2 Alcatel One Touch Fierce Teardown: Schritt 13, Bild 2 von 2
    • I now have a functional phone without an LCD screen.
Jonathan Ruiz
1.322 Reputation
2 Anleitungen geschrieben
18 Kommentare
I'm so glad I found this link!!! I broke the screen on my phone two weeks after I bought it, and refused to pay someone $80 to fix it (I didn't pay that much for the phone!). I have NO experience replacing a cell phone screen and this teardown looked pretty straightforward, so I figured it was worth a try. The step by step was easy, worked perfectly, and I can finally see my screen! YAY! Thank you!
Note: Use patience, and it's a breeze!
Barbara Prather - Antwort
I also successfully repaired my phone although this guide made it seem like you couldn't do it without ruining the LCD. I'm pretty proficient in phone and electronic repair but I think even beginners could do this one. The new glass that I bought had adhesive already applied to it so I could see exactly where it would be adhered from the factory. I heated the front with a heat gun and started at the top left corner. Once I got a pick in there I started going into the gap with a little X-Acto knife, cutting away at the foam like adhesive. I worked my way down the left side, then went back to the right side, cutting as I went. When only the bottom was attached, I held the phone by the top of the glass and let it dangle. Using the heat gun on the bottom of the glass allowed the weight of the phone to separate itself from the glass. Cleaned it up and put the new glass on, works like new again.
Dan - Antwort
I'm about to give this a try Dan. Thanks for your encouragement. Just one question: how did you "clean it up" before putting on the new one? Thanks!!
Janene -
this actually helped! thanks to posted this , my screen broke and ordered it online (ebay) it took a week to get here but man i couldnt see anything with my whole screen cracked! it was cheap as well, 20 bucks with tools! but this really helped!!! just do it calm and slowly , its my first time changing a screen on a phone, this really helped! thanks!
kevin - Antwort
I cracked the camera screen on the back a week after buying the phone. Can you tell me where I can get a new one?
thanks!
Shannon - Antwort
Where do I get parts for alcatel 7040N
prince - Antwort
How can I fix my alacatel one touch anttena
Kewis Walters - Antwort
I was pushing On the power. Button with the cover off and damaged the power button how do i put on a new one
jghost285 - Antwort
If I just wanna replace a cracked screen do I have to do all of these steps also the new screen I ordered did not come with any adhesive should I buy some and if so what kind
Rickvjoe Jay - Antwort
Great! Im having a problem with no sound, after replacing the glass. Get faint sounds from bad headphone jack, but not speaker.
Gary - Antwort
How to replace the power button? I opened the phone and the little silver piece on the power button cable fell off.
pat - Antwort
So how do you fix the plates that fall out the power button
Earl Reeves -
Good night where I can buy volume button Alcatel One Touch Fierce?
Freddy aguilera - Antwort
I know this is an old post but is this teardown the same for the Alcatel One Touch Pop Mega LTE?
sanchezkk - Antwort
Pls where can I get d calibration
habbey habbey - Antwort
Any Alcatel shop where to repair it
My phone don't come apart how can it be replace
Estella Robinson - Antwort
Where is the loudspeaker? I need to change mine out.
Ryan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 62,840
