Zum Hauptinhalt wechseln
Was du brauchst
Videoanleitungen
Dieser Teardown ist keine Reparaturanleitung. Um dein Amazon Echo Dot 2nd Generation zu reparieren, verwende unsere Fehlerbehebungsseite.
en de
100%
Hier starten ›
5 Kommentare
Great video! Can you do one of the Moto Mod Alexa?
Jon - Antwort
Could you make a video of the 3rd generation echo dot
James watling - Antwort
I agree, could you make a video of the 3rd generation echo dot ?
Lance Beden - Antwort
Thanks for the Video! Could you post, which LED driver has been used in the Echo Dot 2nd Gen? Thanks a lot!
Simon - Antwort
Found it on another Teardown-site: It’s a 36 channel LED driver with I2C connection with the name “IS31FL3236”. Although the datasheet is dated from Sepember 2016 the chip already seems to be on “NRND” state (not recommended for new designs)… Strange.
Simon -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 87
Insgesamt: 15,428
