Einleitung
Diese Videoanleitung zeigt, wie du das Echo Dot 2 zur Fehlersuche und Reparatur zerlegen kannst.
Was du brauchst
Videoanleitungen
en de
100%
Hier starten ›
5 Kommentare
Great video! Can you do one of the Moto Mod Alexa?
Jon - Antwort
Could you make a video of the 3rd generation echo dot
James watling - Antwort
I agree, could you make a video of the 3rd generation echo dot ?
Lance Beden - Antwort
Thanks for the Video! Could you post, which LED driver has been used in the Echo Dot 2nd Gen? Thanks a lot!
Simon - Antwort
Found it on another Teardown-site: It’s a 36 channel LED driver with I2C connection with the name “IS31FL3236”. Although the datasheet is dated from Sepember 2016 the chip already seems to be on “NRND” state (not recommended for new designs)… Strange.
Simon -
