Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Amazon Fire Stick 4k zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Amazon Fire Stick 4k Remote Teardown, Heat the remote to loosen the glue.: Schritt 1, Bild 1 von 1
    • Heat it a lot if you are trying to maintain it in working order because it seems the glue on the clasps was very strong. I probably broke mine taking it apart (but it didn't work anyway so I don't know).
  2. Amazon Fire Stick 4k Remote Teardown, Pry it apart.: Schritt 2, Bild 1 von 2 Amazon Fire Stick 4k Remote Teardown, Pry it apart.: Schritt 2, Bild 2 von 2
    • It takes A LOT of force to pry this apart. I'm not sure it's possible without breaking the inside.
  3. Amazon Fire Stick 4k Remote Teardown, Remove the seven motherboard screws.: Schritt 3, Bild 1 von 1
    • Very easy to remove with the #0 phillips screwdriver.
  4. Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: Schritt 4, Bild 1 von 3 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: Schritt 4, Bild 2 von 3 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: Schritt 4, Bild 3 von 3
    • Once the screws are removed, all the pieces come out easily.
Nathan Ruffing
593 Reputation
2 Anleitungen geschrieben
Ein Kommentar
Thanks for the teardown, new firestorm 4k has a couple of screws under the round wheel, but you can pop that off and the remove.
. I used a pair of pliers to just rip off the mic, it is surface mounted and comes away with the pads and remote still works. Small amount of glue on the inside.
Scott - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 55
Insgesamt: 3,560
