Zum Hauptinhalt wechseln
Dieser Teardown ist keine Reparaturanleitung. Um dein Anker LC-90 Rechargeable Flashlight zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: Schritt 1, Bild 1 von 3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: Schritt 1, Bild 2 von 3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: Schritt 1, Bild 3 von 3
    • Unscrew the battery cap
    • Remove battery
    • The cap is heavily tightened from the factory, therefore it may be necessary to use a rubber mat for added grip.
  2. Anker LC-90 Rechargeable Flashlight Teardown: Schritt 2, Bild 1 von 1
    • Unscrew the lens holder as shown in the picture
  3. Anker LC-90 Rechargeable Flashlight Teardown: Schritt 3, Bild 1 von 3 Anker LC-90 Rechargeable Flashlight Teardown: Schritt 3, Bild 2 von 3 Anker LC-90 Rechargeable Flashlight Teardown: Schritt 3, Bild 3 von 3
    • Slide the lens housing down, toward the base, to remove
    • Note that once the lens housing is pushed down the lens and reflector pop out.
  4. Anker LC-90 Rechargeable Flashlight Teardown: Schritt 4, Bild 1 von 1
    • The Anker LC-90 is now tore down
6 Kommentare zur Anleitung
cannot buy parts or return
JULIA - Antwort Teilen
have an l90 by anker
where can i get parts
seems to need new assembly where u plug in usb
Have 3 LC90 flashlight with the same problems, switch stuck & intermittently works! Need 3 replacement cap/switches part #??
Ray Miller - Antwort Teilen
Where can I find a replacement bulb assembly for an anker bolder flashlight?
richard pare sr - Antwort Teilen
Thanks for the information. Took the flashlight battery out and then put in back in; seems to be working great for now!
Steve Moss - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 23
Letzte 30 Tage: 89
Insgesamt: 6,014
