Einleitung
We've been itching to get our hands on the Anki Drive system since it was first unveiled at Apple's WWDC. Now that it's finally rolled in, it feels like Christmas morning at iFixit, with itty bitty plastic cars zipping overland and underfoot. But as much as we'd like to keep reenacting our favorite scenes from The Fast and the Furious films, it's time to find out what lies under those tiny robotic hoods.
Looking for the inside track on iFixit? Enjoy our drive-thru Instagram, park it on our Facebook page, or race on over to our Twitter feed.
Was du brauchst
Anki is a tech startup aiming to bring artificial intelligence and adaptability to objects in the physical world. Their first offering to the masses: Anki Drive.
The starter kit we laid hands on contains the following:
Two Intelligent Cars
Two Charging Cases
Fast Charger
3.5’ x 8.5’ Race Mat
Tire Cleaning Pad
There was no way we were going to proceed to the teardown without trying the Anki Drive first.
So guess what we did.
With no special hardware in the track, and only a rudimentary image sensor and microcontroller in the car, just how does Anki Drive work?
Looking closely at the track, we found its surface is covered in tiny ridges of varied patterns.
With unique patterns along the track, the Anki car can read a single mark and know exactly where it is—then read a second and know where it's going, and at what speed.
The Anki Drive starter kit includes two cars equipped with optical sensors, wireless chips, and motors.
Not a lot of processing happens in the Anki car itself—a base station iPhone or iPad running the Anki app interprets data, plans out the car's strategy, and sends control information back.
The cars come with heavy-duty plastic cases that double as charging cradles, connecting via micro-USB to the Fast Charger.
A single Phillips #0 screw secures the body to the chassis.
That means no adhesive, no security screws, and no complications of any kind to hinder chassis replacement.
With all of the fancy processing tasks offloaded to your iDevice, the Anki car needs very little to survive in the wild.
After desoldering the dual motors' leads, the motherboard lifts easily out of the chassis, bringing all of the sensory, communication, and control circuitry out with it.
It even hosts two gear guides to keep the drive gears aligned to their motors, making this motherboard a true multitasker.
This little guy reads its position hundreds of times per second; we must figure out how!
The likely suspect seems to be hiding behind a light guide/lens assembly. We brought it in for questioning.
The lens/guide unit is anchored by two plastic fasteners. They may be lightweight, but the removal process limits their future fastening ability.
The infrared light from an LED is channeled through the light guide to illuminate the track, allowing the imaging sensor to read the patterns as they whiz by the lens—a lot like an optical mouse.
The front side of the motherboard:
STMicroelectronics F051K86 Entry-level ARM Cortex-M0 MCU with 64 Kbytes Flash, 48 MHz CPU, Motor Control and CEC Functions
Nordic Semiconductor NRF8001 Single-Chip Bluetooth Low Energy Connectivity IC
e160 317a
There are a few additional components on the board:
Imaging sensor
Four LEDs: one on the front side and a row of three on the back side
Fullriver 3.7 V lithium battery
With the help of a spudger, we remove the motors from this zippy little guy, leaving him … unzipped.
Twin motors help the rear wheels do double duty, providing both propulsion and some surprisingly snappy steering.
With its motors hanging way out back of the rear axle, this little Ankimobile definitely hails from the controversial Porsche 911 school of car design.
The front wheels' only job is to not fall off. (It's always the little things.)
There isn't much inside the Anki Drive, so we make sure to pull out every little component.
To be thorough, we remove the light guide and 7.1 grams of various weights, used to keep the cars from flying off the track.
Sadly, we suspect exploding toy cars might not pass CPSC muster.
Anki Drive Repairability Score: 8 out of 10 (10 is easiest to repair)
The device contains only three screws, all non-proprietary. Removing a single screw frees the chassis.
There's no adhesive to obstruct repairs. In fact, the only adhesive to be found is a light foam tape that helps secure the battery.
The battery and motors are soldered to the motherboard, requiring specialized repair knowledge.
The track is hefty but easy to dent. While unconfirmed, this may lead to future usability issues.
The wheels and drive gears appear to be glued and/or riveted in and non-replaceable.
22 Kommentare
In step 6, could have the black plastic pieces to guide the gears any wiring?
Could read the gears movement like the old mechanical mouses?
Has more sense to control the movement of the drives...
I agree, look like photo interrupters to measure the speed
I broke my gear guide because they do mechanical block. How can I repair them?
What capacity is the battery? Could it feasibly be swapped for one with more mAh to allow for longer play?
Today I determined they are 75mAh.
I asked myself the same question about increased capacity.
You can find the mini/micro equivalents on many sites (not necessarily Fullriver) but I cannot find a mini/micro of larger capacity.
In the first instance though I merely want to repair the cars that will no longer hold charge because they have not been used in a while.
giles -
Only now is this page coming up in my search results!
giles -
The black pieces look like hall effect sensors to me - possibly to detect other nearby cars(?)
I have to agree with Jay, the "gear guides are most probably photo interrupters, looking at step 9 2nd photo you can even see the slots in the gear and in step 8 it looks like there are 4 solder pads, just like a photo interupter.
Has anyone hacked these cars with bigger batteries? How big have you gone?
I'm going to report back after I do more research and hack my kids cars. ;-)
They come with a micro sized battery of 75mAh (as posted above). I cannot find an increased capacity of equal size.
I can find one of increased capacity of greater size / weight (roughly double weight) that may fit but is unlikely to and also has a completely different connector without wires, which I suppose could be overcome if it would fit.
Of course a greater charge time would be needed that sort of defeats the object of about 20 minutes play with a roughly 10 / 11 minute recharge time.
giles -
If changing the battery is your only goal then Step 6 desoldering the dual motors' leads is unnecessary.
The board can be flipped out from the other end leaving them connected by careful levering (finger nails or small jewellers' flat head screwdriver) each of the side of the board alternately whilst at the same time applying slight sideways pressure on the small black retaining clips on either side of the black plastic car chassis just after it tapers inwards on each side.
Worked for me anyway and I now have clear access to the battery connectors to desolder and replace.
Sticky black spongy material easily comes off old battery to apply to new one.
giles -
What about Overdrive? Isn't it the same? Also. I would love for you guys to tell me the motors of the overdrive cars guardian and groundshock, mine are... a little bit busted
Anyone know the discharge rate of the 3.7v 75mAh battery? Is it 20c? I'm looking to try and bump the capacity to 100mAh if it will fit.
After a day of use (and maybe by pushing the car in the wrong direction the gear attached to the motor lost it’s symmetry and blocks the wheel. Does anyone has specs or a proposal for fixing it?
I know it is late in the game and instead of just reading through everything, I will tell you that there is a 110mah battery that is a tad longer and a lot thinner, but will fit. I am 100% positive that this does increase the run time. And they are so easy to change. Desolder, add a touch of ROSIN flux (No other kind, please), re-solder. Rosin core flux is used in electronic soldering repair. Get it at Radio Shack and other places.
I did replace the batteries with 200mah 501522 and it’s all good . I thought it would fix the issues I encounter with one of the cars: insane difficulty driving uphill .. barely going on an overpass! What could be causing that? The motor needs to be replaced as well?
