Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Apple Universal Dock Model A1256 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Apple Universal Dock Model A1256 Teardown, Apple Universal Dock Model A1256 Teardown: Schritt 1, Bild 1 von 1
    • Pry along the edge of the bottom of the case. It will just pop out.
  2. Apple Universal Dock Model A1256 Teardown: Schritt 2, Bild 1 von 1
    • Remove the top case from the bottom.
  3. Apple Universal Dock Model A1256 Teardown: Schritt 3, Bild 1 von 1
    • There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
  4. Apple Universal Dock Model A1256 Teardown: Schritt 4, Bild 1 von 2 Apple Universal Dock Model A1256 Teardown: Schritt 4, Bild 2 von 2
    • The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
  5. Apple Universal Dock Model A1256 Teardown: Schritt 5, Bild 1 von 2 Apple Universal Dock Model A1256 Teardown: Schritt 5, Bild 2 von 2
    • The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Devilac
67 Reputation
1 Anleitung geschrieben
Ein Kommentar
Can the actual dock insert (the section the iPod would clot on top of) be used in an Apple iPod HiFi repair? (see repair article Apple iPod Hi-Fi iPod Dock Inserts Replacement)
Harrison C - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 40
Insgesamt: 24,644
