Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Asus Chromebit CS10 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: Schritt 1, Bild 1 von 3 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: Schritt 1, Bild 2 von 3 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: Schritt 1, Bild 3 von 3
    • The top image is the Chromebit with dust cap on its box next to a standard Sharpie for scale.
    • The circled screw in the second image is the write-protect screw, if you remove this and reassemble the Chromebit, if you boot in Developer Mode you are able to unlock the software write-protect and modify/replace the system firmware.
    • Using an iFixit spudger in the USB port stand it up to increase the gap to the sides of the USB port where you can insert a second spudger or a guitar pick and run it down each of the sides of the Chromebit to pop the case loose.
    Frag FixBot
    Kommentar hinzufügen
ComputerPhreaks Mitglied von ComputerPhreaks
Business
1 Mitglied
5 Anleitungen geschrieben
2 Kommentare zur Anleitung
How did you get this open? I’ve been using the spudger with out any luck. Is the case glued on by any chance? Thanks
Jimbo - Antwort Teilen
If you turn the end of the spudger sideways to get it started you should be able to undo the clips around the edges with a guitar pick. There is some resistance from the thermal pad.
dragon788 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 25
Letzte 30 Tage: 106
Insgesamt: 3,512
