Was du brauchst
Four screws and one cable will remove the speaker assembly.
Three screws and a pop on connector secure the micro-SD reader.
There are several screws that hold the battery tray in place. The battery is held in with fairly strong adhesive, so I didn't try to take it out of the tray.
Three cables are attached to the touch board. I didn't try to remove this board from the frame.
Disconnect the four cable connectors that lay across the battery. The cables with blue tabs do not have a locking mechanism holding the cable in place.
There are two magnets located at the bottom center. More than likely used for a case cover or for a feature not included on this tablet.
Once the boards, speakers, and micro-SD card reader have been disconnected, the frame is left sitting on top of the LCD-digitizer.
There are nine screws holding the frame in place.
Remove the frame and the LCD, micro USB jack, and digitizer can be accessed.
Two screws hold the micro USB jack in place.
Two screws hold the LSD in place.
All Parts laying out after disassembly.
Please pardon the debris on the desk.
2 Kommentare
You mention that the power connector is held in place by two screws. Would it be possible to add an arrow or circle to the picture showing where the screws are?
Also there is a surface mounted switch on the main board just above the battery on the left as viewed from the rear. Do you know what it is for? Disabling battery maybe?
