Zum Hauptinhalt wechseln
Dieser Teardown ist in Bearbeitung – Lade die Seite regelmäßig neu, um die neuesten Änderungen zu sehen!
Was du brauchst
Einführungsvideo
  1. Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: Schritt 1, Bild 1 von 3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: Schritt 1, Bild 2 von 3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: Schritt 1, Bild 3 von 3
    • The back panel is removed.
    • The SSD is removed.
IT FIX
6.340 Reputation
74 Anleitungen geschrieben
12 Kommentare
Bonjour,
Je n' arrive pas a voir le disque dur de l' ordinateur. Est il accessible?
Peut il être changé ?
schauch - Antwort
You mean that you pc can’t see the hard drive? Even in bios?
IT FIX - Antwort
Boni can't see it on the video. I d like to buy one of these laptop and change the hard drive for a bigger one. Is it easy to do it?
schauch - Antwort
It’s very easy but it’s supports only M.2 SSDs
IT FIX - Antwort
Hi there,
I own this laptop, and the internal fan has started to make rattling-like noises, as well as suddenly stopping and starting after a period of watching videos and the like. I am wondering if this is due to dust clogging the CPU fan, and whether compressed air can be used to clean up. If it’s not due to dust clog, what else might be the problem?
Thanks.
Sai - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 24
Insgesamt: 6,438
