Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Asus ZenWatch 3 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Asus ZenWatch 3 Teardown, Let's begin: Schritt 1, Bild 1 von 1
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: Schritt 2, Bild 1 von 2 Asus ZenWatch 3 Teardown, Band Removal: Schritt 2, Bild 2 von 2
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: Schritt 3, Bild 1 von 1
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: Schritt 4, Bild 1 von 1
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: Schritt 5, Bild 1 von 1
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: Schritt 6, Bild 1 von 1
    • Battery
  7. Asus ZenWatch 3 Teardown: Schritt 7, Bild 1 von 1
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: Schritt 8, Bild 1 von 1
    • Complete disassembly
Reon
141 Reputation
1 Anleitung geschrieben
20 Kommentare
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - Antwort
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - Antwort
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - Antwort
What should I do if the power button doesn’t work?
MichaelKing10or - Antwort
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 62
Insgesamt: 14,586
