Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Audiophase Dual-Alarm Clock Radio zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Unscrewing the Outside: Schritt 1, Bild 1 von 1
    • Unplug the Device and Take Out Spare Battery on the Bottom of the Device!!!
    • There are five screws on the bottom of the device, one at each corner and a single screw in the middle top section of the device.
    • Unscrew all five screws with your Phillips Screwdriver and place all screws in a safe bag.
  2. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Take off the Bottom Casing: Schritt 2, Bild 1 von 1
    • Pull off the bottom casing of the device gently by slowly pushing the bottom part off on all sides of the device. Pull gently on the casing as there are wires that are connected to it still.
  3. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Removing the Screen from the Top Casing: Schritt 3, Bild 1 von 1
    • Remove all Screws after lifting the bottom part to detach the casing from the circuit board and screen.
    • Gently remove the smaller circuit board and set the top casing aside in a box.
  4. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Observing the Screen, Speaker and Circuit Boards: Schritt 4, Bild 1 von 3 Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Observing the Screen, Speaker and Circuit Boards: Schritt 4, Bild 2 von 3 Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Observing the Screen, Speaker and Circuit Boards: Schritt 4, Bild 3 von 3
    • After the top casing has been removed, you can now see the circuit board, electronic screen, speaker and radio parts.
    • Gently pull out (without pulling the wires apart) the speaker and smaller circuit board.
  5. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Removing Wire Tightening Parts: Schritt 5, Bild 1 von 1
    • Unscrew the Gold painted mechanism on both ends and place screws in a bag.
    • Gently lift out the part to loosen the wrapped wires.
  6. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Pulling out the Shaped Wire: Schritt 6, Bild 1 von 1
    • Gently pull out the wire that is wrapped in the "circular-shaped wire shaper".
    • This will allow you to pull apart the circuit board by loosening the shaped wire.
  7. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Releasing the Circuit Board: Schritt 7, Bild 1 von 2 Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Releasing the Circuit Board: Schritt 7, Bild 2 von 2
    • Undo the glue wires by stabbing the glue with the Phillips Screwdriver.
    • Unwrap the cords from the shaped wire.
    • Prepare to take out the backup battery plug.
  8. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Releasing the Circuit Board Pt. 2: Schritt 8, Bild 1 von 2 Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Releasing the Circuit Board Pt. 2: Schritt 8, Bild 2 von 2
    • Gently Pull out the Backup battery plug (Should be colored blue with 9V Battery Plugs)
    • Pull it through the opening on the inner casing of the device (Notice the Index Finger pointing to it).
    • Release the Circuit Board.
  9. Audiophase AMFM Dual-Alarm Clock Radio Teardown (1999), Teardown Complete: Schritt 9, Bild 1 von 1
    • Pull all pieces apart from each other.
    • You have now torn down the Audiophase AMFM Dual Alarm Clock Radio!
    • This Device can be reassembled by following the disassembly directions in reverse order.
Dylan MH
21 Reputation
1 Anleitung geschrieben
1 Kommentar zur Anleitung
Not coming on even clock light
Rajendran - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 27
Insgesamt: 1,851
