Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein BSP-D9 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. BSP-D9 Teardown, Opening the controller: Schritt 1, Bild 1 von 1
    • To open the controller there are 8 screws on the rear that need to be remove to access either side of the controller.
    Frag FixBot
  2. BSP-D9 Teardown, Opening the left side: Schritt 2, Bild 1 von 2 BSP-D9 Teardown, Opening the left side: Schritt 2, Bild 2 von 2
    • We start with the left side as the battery is this side.
    • Start by squeezing the indicated area with your thumb
    • Then twist whilst pressing the squeezed area to open the controller to the left similarly to a book. As shown in the second image
    Frag FixBot
  3. BSP-D9 Teardown, Disconnecting cables: Schritt 3, Bild 1 von 2 BSP-D9 Teardown, Disconnecting cables: Schritt 3, Bild 2 von 2
    • There are 4 connections hold the top piece in as labelled
    • 1. Rumble motor connection
    • 2. Macro Button connection
    • 3. Battery connection
    • 4. Interconnect Flex Cable
    • Disconnect the battery first before disconnecting anything.
    • To disconnect the ZIF connector by picking on the grey bale. As shown
    Frag FixBot
  4. BSP-D9 Teardown, Left Side PCB Removal: Schritt 4, Bild 1 von 1
    • In order to remove the PCB, unscrew the two screws as shown
    Frag FixBot
  5. BSP-D9 Teardown, Left Side Toredown: Schritt 5, Bild 1 von 1
    • And with that the left side is tore down.
    Frag FixBot
  6. BSP-D9 Teardown, Right Side Opening: Schritt 6, Bild 1 von 2 BSP-D9 Teardown, Right Side Opening: Schritt 6, Bild 2 von 2
    • Apply pressure in the region highlighted in the images.
    • After which twist the controller in the direction shown
    Frag FixBot
  7. BSP-D9 Teardown, Right Side Cable Disconnect: Schritt 7, Bild 1 von 1
    • There are 3 connections for the right side.
    • 1. Interconnect Flex Cable Connector
    • 2. Rumble Motor Connector
    • 3. Macro button Connector
    • To disconnect the flex cable follow the same steps as the left side
    Frag FixBot
  8. BSP-D9 Teardown, Removing the mainboard (R): Schritt 8, Bild 1 von 1
    • Remove the screws highlighted in the image
    Frag FixBot
  9. BSP-D9 Teardown, Right Side Toredown: Schritt 9, Bild 1 von 1
    • That's the right side torn down.
    Frag FixBot
6 Kommentare zur Anleitung
What about the middle, extensible part? My Bsp-D9 stops working when fully extended, I think that part might be the problem.
Maxime Lumeau - Antwort Teilen
Hi there @maximelumeau It's possible that either the ribbon cable that connects both sides is broken or it has come disconnected.
The only way to check is check continuity using a multimeter for each connection in the ribbon cable or replace the ribbon cable with one of same specification respectively
Neville Davids - Antwort Teilen
What type of flex cable is that and how many pins are in it . Also do you know the space between the pins
Daniel Pax - Antwort Teilen
15 pin cable not sure of the pitch as I don't have a clamp to confirm the pitch
My R2 and L2 was accidentally bent up in my suitcase so the little plastic tab broke off, and now they get stuck when pressed down and feels like they give resistance. Do you know any fix for this?
Bear Kuma - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 39
Letzte 30 Tage: 175
Insgesamt: 3,840
