Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Binbok EVO Pro Controller zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Binbok EVO Pro Controller Teardown, Remove six screws from the back.: Schritt 1, Bild 1 von 3 Binbok EVO Pro Controller Teardown, Remove six screws from the back.: Schritt 1, Bild 2 von 3 Binbok EVO Pro Controller Teardown, Remove six screws from the back.: Schritt 1, Bild 3 von 3
    • Use a Phillips #0 screwdriver.
    Frag FixBot
    Kommentar hinzufügen
  2. Binbok EVO Pro Controller Teardown, Lift the back cover off.: Schritt 2, Bild 1 von 1
    • The cover pulls off without much resistance.
    Frag FixBot
  3. Binbok EVO Pro Controller Teardown, Unplug the battery and the rumble motors.: Schritt 3, Bild 1 von 1
    • Peel the battery up carefully. The adhesive is sticky and lifts easily off the PCB. I was a bit worried about being able to put the battery back, but the adhesive is sufficiently sticky to re-install it.
    Frag FixBot
  4. Binbok EVO Pro Controller Teardown, Remove six screws from the PCB.: Schritt 4, Bild 1 von 1
    • Four screws are near the middle of the PCB while two screws are hidden away near the motors.
    Frag FixBot
  5. Binbok EVO Pro Controller Teardown, Lift the PCB out.: Schritt 5, Bild 1 von 1
    • Insert wisdom here.
    Frag FixBot
  6. Binbok EVO Pro Controller Teardown, Pull the silicone button covers out.: Schritt 6, Bild 1 von 2 Binbok EVO Pro Controller Teardown, Pull the silicone button covers out.: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • The covers each have little inserts that can be pulled through with tweezers or pliers when re-installing them.
    Frag FixBot
  7. Binbok EVO Pro Controller Teardown, ALPS joysticks.: Schritt 7, Bild 1 von 1
    Frag FixBot
  8. Binbok EVO Pro Controller Teardown, All the parts.: Schritt 8, Bild 1 von 1
    Frag FixBot
  9. Binbok EVO Pro Controller Teardown, It works!: Schritt 9, Bild 1 von 1
    • I put the controller back together and it still works!
    Frag FixBot
Tim McMahon
184 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 46
Insgesamt: 1,280
