Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Black Diamond Moxie zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Black Diamond Moxie Teardown, From the Outside: Schritt 1, Bild 1 von 3 Black Diamond Moxie Teardown, From the Outside: Schritt 1, Bild 2 von 3 Black Diamond Moxie Teardown, From the Outside: Schritt 1, Bild 3 von 3
    • Pull here to open the battery case
  2. Black Diamond Moxie Teardown, The Battery Case: Schritt 2, Bild 1 von 2 Black Diamond Moxie Teardown, The Battery Case: Schritt 2, Bild 2 von 2
    • Space for three AAA batteries here
    • Unscrew these
    • and these phillips screws here.
    • Keep in mind, that this are different screws, so don't mix them
    • This part will be a bit complicated to get it back together
  3. Black Diamond Moxie Teardown, The Front: Schritt 3, Bild 1 von 3 Black Diamond Moxie Teardown, The Front: Schritt 3, Bild 2 von 3 Black Diamond Moxie Teardown, The Front: Schritt 3, Bild 3 von 3
    • The front has three parts
    • The case,
    • the reflector
    • and the lens.
  4. Black Diamond Moxie Teardown, The PCB: Schritt 4, Bild 1 von 2 Black Diamond Moxie Teardown, The PCB: Schritt 4, Bild 2 von 2
    • The "high power" LED with 55 lumens
    • This seems to be a cooling plate for the high power led
    • The other two LEDs with 16 lumes
    • The button
  5. Black Diamond Moxie Teardown, The Light Spot without the Lens: Schritt 5, Bild 1 von 2 Black Diamond Moxie Teardown, The Light Spot without the Lens: Schritt 5, Bild 2 von 2
    • The high power LED would make a way better near field wide angle lamp without the lens.
    • In reality the light is even broader distributed than visible on the image.
    • This is the light spot of the two low power LEDs.
  6. Black Diamond Moxie Teardown, The Manual: Schritt 6, Bild 1 von 2 Black Diamond Moxie Teardown, The Manual: Schritt 6, Bild 2 von 2
    • The english part of the manual
Quanten
727 Reputation
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 22
Insgesamt: 1,285
