Einleitung
to see the full video open:
BlackBerry Porsche design P'9981
Was du brauchst
Einführungsvideo
remove the security clasp so u can pull out the screen's ribbon cable carefully
now the screen is out of the metal chassis
insert your metal blade tool carefully between the screen's chassis and the on screen keys to remove it's panel
take it out .. don't worry its glued so u have to pull it out but (carefully)
now remove the small ear piece
now u have to remove the keyboard panel .. from left side insert your metal blade tool between the panel and the metal chassis .. so it can pull out
Finally you are Done
Check the Full video of me on this link :https://youtu.be/_VCZsZ-u8vM
Ein Kommentar
Hello Mostafa,
Thanks for the clear teardown! If you would grade this phone on repairability, according to the iFixit's grading system, what grade would it be and why? (Repairability)
Regards, Guus
