Einleitung
This is a guide to opening the original Blackmagic Pocket Cinema Camera.
Was du brauchst
Begin by removing the rubber facing from the right side of the lens using a spudger or metal blade.
Remove the six small galvanized steel PH0 screws (not the black ones) from their holes through the main board
Unlatch the black latches on the flex cables and gently slide them out with a pair of tweezers.
