Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Fan zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: Schritt 1, Bild 1 von 2 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: Schritt 1, Bild 2 von 2
    • Gather the required tools: a small Phillips head screwdriver and a smart wrench.
    • Make sure the device is unplugged and fan blade is not spinning before starting.
  2. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: Schritt 2, Bild 1 von 3 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: Schritt 2, Bild 2 von 3 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: Schritt 2, Bild 3 von 3
    • Unscrew the clip-on stand that connects the fan. This can be done by hand.
    • Turn the fan so that the back is facing up and remove the screw on the upper part of the housing.
    • Remove the back casing to reveal the switch's screws on the inner part of the casing. Remove those as well.
    • The switch's settings:
    • Off (center)
    • Speed 1 (left)
    • Speed 2 (right)
  3. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: Schritt 3, Bild 1 von 2 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: Schritt 3, Bild 2 von 2
    • Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
    • Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
  4. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: Schritt 4, Bild 1 von 2 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: Schritt 4, Bild 2 von 2
    • Now that the blade is removed. The motor can now be removed from the other half of the housing.
    • Remove the two screws indicated in order to take the module out of the plastic.
    • The motor is connected to the blue transformer. The yellow and white wires indicate the two power outputs for the speed of the motor's rotation.
  5. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown: Schritt 5, Bild 1 von 1
    • That's it! There isn't too much when taking this device apart.
    • Note: You can further expand on the teardown by taking apart the transformer to DC motor set-up, but it's such a simple circuit that it isn't necessary to look at it.
Justin
111 Reputation
1 Anleitung geschrieben
4 Kommentare
Hi How do you find the replacement switch?
sadeyealso - Antwort
the switch melted….
Hi, I was wondering where I could find a clip and base for a 6 inch fan. The fan itself works just fan. Preferably it should be an online store.
Thanks for reading.
Nova Apex - Antwort
Is it possible to purchase a replacement blade?
Wayne - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 4,353
