Einleitung
CH7284/E DOCSIS/EuroDOCSIS 3.0 16X4 Wireless Voice Gateway
The CH7284/E includes a dual band concurrent 2x2 2.4GHz 802.11n and 3x3 5GHz 11ac wireless access point and an enhanced tuner that supports up to a 1GHz downstream full band capturing that allows operators to increase the frequency spectrum for deployment of new high-value services, such as remote diagnostics, bandwidth on-demand, commercial services, interactive gaming, and IPTV to their customers.
2.4GHz 802.11n/5GHz 802.11ac AC1500
- LAN:Two 10/100/1000 Mbps auto-sensing , Auto Uplink RJ-45 ports
- One RJ-11 voice port
- 2.4 GHz 2X2 11n and 5GHz 3X3 11ac Dual band concurrent
Dimensions: 132x132x36 mm
Was du brauchst
This router has a fan. And it gets dusty. Bring out your can of compressed air!
Remove the nut from the coax port with a wrench.
Lift up the three Wifi antennas from their slots.
Push two plastic tabs downwards (located on opposite side of ports) and lift up the circuit board.
