Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Canon 9950F zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Canon 9950F Scanner Teardown, Taking off the top half: Schritt 1, Bild 1 von 2 Canon 9950F Scanner Teardown, Taking off the top half: Schritt 1, Bild 2 von 2
    • Disconnect cable
    • Lift off top lid
    Frag FixBot
    Kommentar hinzufügen
  2. Canon 9950F Scanner Teardown, Opening the top part: Schritt 2, Bild 1 von 2 Canon 9950F Scanner Teardown, Opening the top part: Schritt 2, Bild 2 von 2
    • Loosen the 6 screws.
    • There are also 3 clips at the top, you can undo them by sliding it a little in the direction of the hinges, then unclipping.
    • When you are moving the scanner parts of the machine, try to do so by moving the gear, as it is intended to avoid damage.
    • Don't forget to put the scanner back to it's original position after you are done cleaning.
    Frag FixBot
  3. Canon 9950F Scanner Teardown, Opening the bottom part: Schritt 3, Bild 1 von 2 Canon 9950F Scanner Teardown, Opening the bottom part: Schritt 3, Bild 2 von 2
    • From the two slots the hinges move out from, undo two phillips screws.
    • Then unclip the plastic cover, it has some clips at the back. Should come out relatively easy.
    • Slide the glass in the direction of the red arrows. Then lift the glass a little by blue arrow and it should come out.
    • Now you can clean the insides and back of the glass.
    Frag FixBot
  4. Canon 9950F Scanner Teardown, Opening the scanner head for cleaning: Schritt 4, Bild 1 von 3 Canon 9950F Scanner Teardown, Opening the scanner head for cleaning: Schritt 4, Bild 2 von 3 Canon 9950F Scanner Teardown, Opening the scanner head for cleaning: Schritt 4, Bild 3 von 3
    • Move the scanner head a little away form its resting position. Again, by turning the gears.
    • Unscrew the the phillips screws at the sides of the head.
    • The head also has about 6 metal clips in total in the two sides. You have to undo 2 to open it for sure. But I undid all, just to be sure.
    • The part shown with the green circle, needed some fiddling to also undo. There are wires here, so pay attention not to damage anything! I just moved it off to the side while cleaning the mirrors.
    Frag FixBot
Ajtony B
109 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 76
Insgesamt: 806
