Einleitung
hello all,
today we wil take down the canon pixma ip4850.
This printer has the wel know problem : B200.
Most of the time this is a printhead problem.
you will see how you can replace the printhead and other parts. enjoy !
be carefull : its not an easy guide!
Was du brauchst
this printer has the well known B200 error.
we will take the printer apart.
first step : remove all the loose parts.
remove the panel at the back.
no we will remove the printhead and the cardridges.
To remove the printhead you have to plug in the printer again and open up te front panel (like you have to remove the cardridges).
to remove the printhead you have to pull the levar up (grey) , be carefull its very rough to pull it up.
remove the printhead, if you only replace the printhead the guide stops here. be carefull for the pcb board, if you only clean the printhead do it carefully. clean it with destilled water, but do not touch the PCB.
remove the papertrunk at the botom, see picture 3
now remove the screws at the white clips.
now we will remove the power supply.
you'll find clips to loose the power suply . On the picture (number 1) you see how you do it. you'll here the clicks.
pull the power supply out of the printer, and you will see the white and blue wires. you will see this wires later in the printer again.
remove the side panels
you can remove this by clicking the panel of.
search for the arrows on the upper deck of the printer. see picture 1
than click the panel losse at the bottom of the printer.
remove the upper panel by clicking two clips. at the backside.
normaly , if my guide is good enough, the printer looks like picture 3 now.
remove the printer paper roll
remove the red circled screws.
this step and the next is actualy 1 big step.
remove the 2 screws. one on a PCB board and the other in the white plastic.
remove the long PCB , remove the three thick screws
remove all the wires, some are attached to the PCB.
now you can remove the paper roll.
now remove the metal plate (long) , 4 screws in total. 1 screw is attached at an PCB board.
the pictures here are to remove the other metal plate, you'll see the colored wires running trough. remove the plastic and metal frame
in this step we will remove the panel and PCB of the power button.
remove the visible screws and pull the plastic frame off.
remove the metal plate and screw behind the PCB board
remove the plate and remove the hidden screws
gently remove the ink tubes.
there is still inkt left in the tubes so use cotton towels or tissues.
in the last pictures you will see all the parts like the motor PCB boards, power button print head holder ...
hope this guide helped you out.
4 Kommentare zur Anleitung
Fixing back the printer but the connector wires are damaged in the ends any better way to get the connectors working again?
unfortunately the Pixma MP printers and AIO are one of the most complicated to repair and undocumented in service guides printers in the world :(
Bonsoir,
Félicitations pour ce super tuto !
J'ai cherché sans succès sur le site son semblable pour une imprimante CANON IP 7250.
J'ai reçu un code B200 ; nettoyage tête d'impression et absorbeur d'encre.
J'avais rencontré ce problème il y a 2 ans et l'avais résolu en nettoyant la tête d'impression avec de l'eau distillée, mais cette fois c'est insuffisant. Il me faut passer à l'étape absorbeurs beaucoup plus lourde. Auriez-vous un tuto pour cette imprimante ou pourriez-vous m'indiquer le processus pour y accéder ?
NB : le démontage de la machine est fortement avancé.
Par avance, un grand merci, je ne voudrai pas rentrer dans le jeu de CANON consistant à forcer la vente au détriment d'une réparation.
Tous vos conseils seront bienvenus.
Bonne soirée. Dan
