Einleitung
This guide outlines the steps in tearing down your camera to its basic components.
Was du brauchst
On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
Remove the four 4.75 mm screws that sit at the bottom of the camera.
On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
Remove the two small metal plates, which the four screws hold in place.
Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
Detach the front case and back case.
Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
Gently release the black latch.
Remove the ribbon cable and metal plate assembly.
On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
Remove the second 3.5 mm screw that sits directly above the LCD screen.
Gently detach the ribbon cable.
Locate the ribbon cable on the main circuit board, which sits below the lens.
Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
On the main circuit board, gently release the black latches of the four ribbon cables.
Gently detach the ribbon cables.
In a hinge-like motion, gently lift the bottom of the main circuit board, which is the side without the soldering points.
Gently detach the white ribbon cable from the underside of the main circuit board.
Gently desolder the two ribbon cables attached to the motherboard.
Remove the motherboard.
Working with the lens-flash assembly, remove the three 3.45mm screws located on the metal plate.
Separate the flash assembly from the lens assembly.
Set aside the flash assembly.
Remove the three 2.5mm screws connecting the viewfinder to the rest of the lens assembly.
Displayed here are all of the components of the camera.
To reassemble the camera, follow all of the steps in reverse order.
2 Kommentare
FYI My S400 would not start sometimes. If I banged it in the palm of my hand occasionally it would then work. I was also having terrible trouble with batteries not working and showing low charge when they had been charged.. I opened it up as a last resort. On the front left side below the shutter button there was a small ribbon cable that under a magnifying glass I could see was slightly out of line. I reseated it and the camera has acted flawlessly since.
Am curious - I do not see the “Sensor” in this teardown? My immaculate S400 never dropped, not a scratch or scuff-mark, suddenly stopped working - dead sensor. The shutter still works and it can play images taken on another camera. But the display is near-black in record mode and images taken are “pure black”. It literally went from perfect to dead in one power-cycle. I was wondering if something may have come loose in there that a tear-down would identify?
